S13FX »
https://forums.nicoclub.com/s13fx-u28329.html
Wed May 24, 2006 5:03 am
Also replace the water pump or just the gasket for it, and when you reflush your system make sure you get all the air bubbles out. On our cars it's really simple do to the bleeder screw we have on the intake manifold .
Also if you said you had water boiling in your overflow tank but your car didnt show that it's overheating replace your thermostat. Cause whats happening there is the coolant is getting hot, but the thermo is not opening so hot coolant is forced into the overflow tank.
This is what was explaind to me when I had the exact same problem as you, so I went ahed replaced my water pump, reflushed my system, replaced the thermo, and my car is golden now.
