MaineExport »
https://forums.nicoclub.com/maineexport-u157.html
Fri Dec 13, 2002 8:26 pm
There have been several threads about this recently, so I'm sure a search would yield some good advice.
I would try making sure your coolant is full, and bled. Assuming you have already done that.... then:
Replace your thermostat. I had a similar problem recently, although my overheating was very random, and I put in a new thermostat..... still overheated. Then I had the water pump replaced (it had a very small leak and the diaphragm was torn).... still overheated. Finally my mechanic tested the new thermostat that I had put in..... it was faulty.
What I'm trying to say is.... test the thermostat first, and if that's the problem, test the new one BEFORE you install it!
