Overheating problem
jeostang50
Car: 2006 M35
I have a 2006 M35 with 135000 miles on it. Thursday the AC stopped working and I noticed the car was over heating. The over flow tank had no coolant. I had the towed home and did a pressure test on the cap. The cap was out of spec so I got a new cap filled the system, drove it around the neighborhood. Again it started overheating. I pulled back into the garage and this time I could see the leak coming from the radiator right under the cap between the plastic tank and radiator core. Has anyone seen this before. I know the car has high miles but this doesn't seem normal.
Thanks
zerg711
Just call it bad luck. I had to replace my radiator on my FX35 right after factory warranty ran out. I was not happy....
jeostang50
Car: 2006 M35
I would not be happy about that either.
But this car has been serving me well, so I'm not upset. Where is the best place to order parts?
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
If you decide to put some work in it, change out your water pump and thermostat... At those miles it would hurt to do preventive maintenance. :gotme
06M4.5
Car: 2006 M45
I would be happy if my radiator lasted 135,000 miles
wingFeather
Car: Current: 05 G35 Coupe
Previous: M35, M35 Sport, cube, J30, s13 sr20det, s13 rb20det, s14 zenki
Let's pray you caught this before it caused any further damage!
nolmt50
Car: 2006 m35
Did you ever get the problem fixed? My car just started overheating today, I'm taking it to Infiniti tomorrow because I had a letter from them about the radiator fans not working properly and they extended the warranty on them. Hopefully that solves it for me, my car has 85k miles.
wingFeather
Nolmt50, did they happen to mention if it was a recall? I am out of warranty, and even though I don't have problems now, I'd like to get the fans replaced if there are known issues.
nolmt50
Car: 2006 m35
wingFeather wrote:Nolmt50, did they happen to mention if it was a recall? I am out of warranty, and even though I don't have problems now, I'd like to get the fans replaced if there are known issues.
It's not a recall, I guess it's just an extended warranty to 8years/100k miles.
Here it is:
lovemycarM35
Car: 2014 Lexus GS 350
With F-Sport Package
Nebula Gray
19" wheels
12.3 inch display
Navigation
Hey does this apply to the 2007 M
lovemycarM35
Nebula Gray
19" wheels
12.3 inch display
Navigation
nolmt50
Car: 2006 m35
lovemycarM35 wrote:Hey does this apply to the 2007 M
Call the number with your vin and I'm sure they will let you know.
06M4.5
Car: 2006 M45
yes 1st owner had it done to my car
