Overheating Problem
Xoltol
Well My oh so lovely 240 Just loves to overheat ~_~
It goes like this: Driving along... look at temp It's Past the Hot marker... 3 minutes later.. it's back to the middle... then later again back over the line...
I put Coolant in there.. it maybe helped for about 20 minutes... then back to the old problems... Also noticed that when i open the Coolant box thing... It's like a murky brown liquid... any idea what to do?
CRyan
Car: 1997 Nissan 240SX
Xoltol wrote:Well My oh so lovely 240 Just loves to overheat ~_~
Flush your system, maybe replace the thermostat, my car likes to get a little warmer (not overheat warm though) and I just replaced it with the nismo thermo and it works great now. runs a little cooler honestly.
sicairos_2007
Car: 3 Nissan 240 Sx
bleed the cooling system sounds like u have air in your system
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
murkey brown?...dude..you might have a blown head ghasket and have oil in your coolant...its a bigger issue than you think..but..good news is its corectable with in a weekend and some tools..keep us posted on what ya find.
http://www.myspace.com/liquid_cool_ka24de
Xoltol
So it probably is a head gasket problem... I know head gaskets are relatively cheap.. i'm seeing em for 30 bucks.. Does anyone have a guide to replacing them? if so it would REALLY help.
nismoracingsx
Car: 1993 White 240sx Coupe
use search button for the HG procedure. Pull your dipstick and see if the oil is milky as well. If you need more confirmation. Go to advance and buy a HG test kit for the cooling system. Relatively cheap.
liquid_cool
if it is your headghasket...get a nice cometic or sumpin...upgrade from that crappy oem one at least..should run ya about$100. bucks.
