craaaazzy »
https://forums.nicoclub.com/craaaazzy-u41444.html
Wed May 31, 2006 2:52 pm
Hi guys,New guy to this forum, great place for information. I have searched and have read all i could about the issue but am still a bit confused.
Here's my problem. Car starts to overheat about 5 minutes into driving, the needle goes up near the H, never gets to the H, but then goes back down to normal if still moving. If I am moving at a slower pace, say 10-25 mph, then the needle goes to about 3/4 - 7/8 up and stays there until i start going at highway speed again (60 mph).
i have done a full coolant change (coolant was brownish in color with only maybe 5 drops of oil in it), flushing the system twice. i have changed the water pump, the thermostat, and radiator cap. i thought maybe my head gasket was the culprit but after a compression test, all seems well (160, 168, 162, 160). also no signs of coolant in the oil.
do i still have an air bubble in the cooling system? should i also replace the radiator?
oh, i've got a 93 240sx w/ 156k miles on it.
funny thing is that i had a slight hesitation problem between 2-3k rpm's which i had tried to solve by new cap rotor, wires, plugs, fuel injector cleaner but nothing seemed to work but after flushing the cooling system, no more hesitation...??? car was also stalling out previously but no more of that either.
any help would be greatly appreciated. tia!
fred
Modified by craaaazzy at 6:07 PM 5/31/2006
