youngun21a »
https://forums.nicoclub.com/youngun21a-u38346.html
Mon Jun 11, 2007 10:54 am
Had the same proablem, spinner came out of new water pump after engine rebuild,put in a new one ,a month later, hose from the back of the block that goes to the heater core,had a leak on it,put in a new one ,it started to overheat, let it idel for 45min,it was fine, drove for half a block, overheat all the way to H!!, Let it cool, came back home, bottom hose cold, remove the Termastat, runs fine now, 3 week later it's started to overheat again only with ac on,turn the heater on back to normal,think is the clutch fan, or somthing is clog condenser fan,running out of ideas1!
1993, 240sx stock,engine rebuid everything new
