Oh Em Zee »
https://forums.nicoclub.com/oh-em-zee-u131853.html
Sat Jun 12, 2010 2:21 pm
the fan isnt needed that much at freeway speeds..
if your problem occurs +65 mph, it is most likely not your fan.
City driving, then yes, it could be your fan.
you've replaced nearly everything but the water pump.
the comments about oil in the radiator fluid are not really that relevant to your overheating problem, but you should of course check.
we do need to know what symptoms of overheating you are having though, what speeds and what visually happens.
another thing worth mentioning because you asked if there could be other reasons for an overheat:
coolant system pressure, (making sure your radiator cap is sealing correctly)
this shouldnt apply to you because you got a new radiator.
lower radiator hose kinking (but you replaced your hose)
incorrect thermostat temperature (but you are having problems before and after replace)
making sure there isnt some ridiculous obstruction in front of the radiator
(seems stupid, but i've found an entire cardboard box stuck in front of my radiator when the previous owner hit it.)
if i think of anything else to look for i'll let you know. there really isnt that much left.
