eastcoastchaos wrote:you probably just have some air trapped in there. run it with the radiator cap off and look for any bubbles. once the bubbles stop your problem should be fixed.it worked for me
Thanks for the suggestion, but believe me, that's not the problem.
The coolant has been changed probably 5+ times and the problem still exists. I have bled out all the air every time.
One thing strange though, when you fill the car up with coolant and let it run until the thermostat opens...you can feel the upper radiator hose get hot after the thermostat opens, but if you look into the radiator, there seems to be no flow. The coolant stays stagnent. Which makes you think the waterpump isn't working, but I just changed that and it has the same problem. Also, the old waterpump appears to be in good condition anyway.
