^ I remember my 1st SR swap it would randomly do that at the heater core hoses. God those things are a PITA!! I used some Gray silicone around those hoses and it finally stopped.hartig wrote:does your radiator stay filled? mine has been overheating, and i noticed that one of the heater core hoses was leaking = letting air into the system and screwing everything up. it was a slow leak too..
and do you have a clutch fan or an e-fan? if neither, you should get one or the other..
Go to the dealership, OEM is best, problems have occured with ones from local autoparts stores.HotCarl wrote:Does it matter what KA thermostat you buy locally....
Thanks
Thermo for all KAs should be the same.HotCarl wrote:I have a blacktop S13 sr20det...I was curious if it matters which model ka thermostat you use? Thanks.
The heater hose in the bay right at the firewall?Lobo240sx wrote:^ I remember my 1st SR swap it would randomly do that at the heater core hoses. God those things are a PITA!! I used some Gray silicone around those hoses and it finally stopped.hartig wrote:does your radiator stay filled? mine has been overheating, and i noticed that one of the heater core hoses was leaking = letting air into the system and screwing everything up. it was a slow leak too..
