overheating problem, kind of.
kaedachef
Car: 1990 Nissan 300ZX N/A
my 1993 240sx ka24de is overheating kind of. What I was told is that there are air pockets in my cooling system. I flushed the system through the radiator, but I broke my relief screw when trying to take it off and couldn't get to the coolant plug on the block. After flushing the radiator and driving it for about 10-15 min the top of my radiator cracked. Could it be from the pressure from the air pockets. Also I replaced my water pump, t-stat, and my temp gauge is reading either half way or a little over (not sure where halfway is). I need help ASAP as this is my daily driver. Thank you
kaedachef
bump
JStrateger
Car: 1992 Nissan 240SX
Is it cold where you live? If so, did you have Anti-freeze or just water in your radiator? How old is the Radiator?
I doubt air pressure in your radiator could build up enough to crack it. It sounds like the radiator was just old and crapped out on you.
kaedachef
just water, but its like 50 degrees out and it ain't getting any colder.
