Postby
OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.htmlFri Dec 31, 2010 8:53 pm
You should not have to re-torqued the head.... What you need to do now is check the deck, then get the head checked, milled, and align bored if needed. I wasn't being a d!ck, but this aint my first rodeo...
Postby
drift_junkE »
https://forums.nicoclub.com/drift-junke-u84331.htmlFri Dec 31, 2010 9:25 pm
Yea, I knew that, I'm just one of those stubborn a** people and I had a bubble that stayed on the temp sensor for about 2 days before. I thought I might have gotten lucky and it been that, but not quite. Fortunately I called it quits before I warped the head or worse, blew the motor all together.
Postby
drift_junkE »
https://forums.nicoclub.com/drift-junke-u84331.htmlSun Jan 02, 2011 3:37 pm
Ok, so the head was pressure tested and resurfaced. It checked out, but now I am still having overheating troubles, still no heat yet temp rises too high. Also still no heat either
current parts status:
New Thermostat
New Water pump
New Radiator
New Head gasket
Fresh fluids
and still no luck with anything. any suggestions?
Postby
drift_junkE »
https://forums.nicoclub.com/drift-junke-u84331.htmlSun Jan 02, 2011 5:42 pm
Yea, I am replacing both temp sensors and lower rad hose tomorrow. I'm not thinking the sensor is bad and that gauge is wrong, but to be on the safe side, and I really hope its just the radiator hose now, next step is to take the dash out and replace the heater core as well as both hoses to it.
Postby
kouki_420 »
https://forums.nicoclub.com/kouki-420-u175465.htmlMon Jan 03, 2011 7:04 pm
first of all. what thermostat and water pump are you using? your overheating should had never happened if you had OEM parts. ive seen advanced auto brand parts take a poop just like that. do it once and buy OEM nissan parts.
Postby
Eion »
https://forums.nicoclub.com/eion-u137552.htmlMon Jan 03, 2011 9:09 pm
OutToWinPAHC wrote:If the radiator is moving it's air..... And chances are because you have been driving it, your head is warped, and you have intermix.
no such thing as a dumb question right? is intermix like coolant and oil mixed together?
