p00t »
https://forums.nicoclub.com/p00t-u5026.html
Sun Aug 24, 2003 1:33 pm
definately sounds like the water pump is dead and/or not sealed right.
the water pump is in the front of the engine, it is driven off of the same assembly that drives the mechanical fan. infact the same pully that drives the fan is what powers the water pump.
my theory of what happened is that the pump was on its way out, and you kept driving with it like that (you didnt know about it im not pointing fingers here). the engine temperature constantly skyrocketed on your way to work (which is very bad for an engine), eventually the hot temperature caused the pump seals to fail and here we are with a leaking malfunctioning pump.
thing to do now is have the pump replaced, and make sure it is resealed properly. also check every spot you can for signs of cracks and leakage, especially with the front cover off as your replacing the pump.
make sure when you refill the coolant you use at most a 50% mix of water and antifreeze. if you live in a warm climate you can drop the mix to 30-40% antifreeze and 60-70% water. When refilling make sure you get all the air pockets out. some people have had trouble bleeding the system of air, putting the car on an upward incline helps if you cant get it bled.
good luck!
