WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Wed Mar 07, 2007 11:53 am
Fill radiator with a 50/50 mix of antifreeze/water. Even if you don't experience freezing conditions, the antifreeze has anti corrosive properties. Start the motor, get motor to operating temp, water will circulate. Keep filling while using the bleed screw to release trapped air. To make things easier, dump one entire gallon of antifreeze in the radiator at first, then use a hose after, the mix will be close enough.
The motor needs to reach operating temp so the thermostat will open and coolant will flow through the entire engine at full flow. This will take awhile since you're putting in fresh cold water from a hose etc. So the process will need to be repeated 4-5 times to insure the vcoolant system is properly filled and bled.
Thats the way I've done it on EVERY vehicle I've owned. Once we get a few more replies, I'll sticky it.
Welcome to NICO by the way.
WD
