modulation »
https://forums.nicoclub.com/modulation-u72502.html
Sun Dec 21, 2008 9:13 am
You aren't going to know until you get in there and found the hose that busted.
Hopefully it's just a hose. I'd replace all those around the area that you saw water spraying from. If you aren't lucky then maybe the metal part of the intake manifold that the hose plugs up to cracked and is leaking..
What sucks though is once one hose goes, they will all start slowly going out. If I were you'd I start replacing them all...
Edit:It might be impossible to find where the hose is leaking from when the hose is at normal temp. Squeeze the hoses and see if any of them feel different, but like I said, I'd just replace them all around that area, and I'd slowly replace all of them.
