overheating light?
atcq110
I have a s13 redtop sr, yesterday the overheting light came on, and now it is staying on all the time, even when the car is cold. My temperature gauge is working fine, fan works fine, coolant level is ok, ans the car runs as it normaly would. Is this just a wiring problem or a bad sensor. Any ideas what it could be or what else i should check? Thanks
Silvia007
Car: 93 Nissan 240SX SE Fastback
Overheating light? WTF is that?
atcq110
The red light to the right of the low fuel light. Looks like a picture of an engine block with smoke lines coming off the top of it. I just assumed thats what it was.
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
no such thing as an overheating light.
maybe you have mistaken the low coolant light for the overheating light?
there is a level switch in the coolant overflow tank. the coolant level in the engine/radiator can be good, but if the overflow tank is low, it will trip the light.
with the engine COLD, check the coolant level in the radiator [remove the radiator cap]. if the level is low, begin filling the cooling system with coolant [50/50 mix].
start the engine, and put the heat on full blast. let the engine run with the radiator cap removed. air should surface, allowing you to add more coolant. once the upper radiator hose begins to become warm, add as much coolant to the radiator as possible.
once it is as full as you can get it, replace the radiator cap.
now fill the coolant overflow tank up to the halfway mark.
drive the car for a little while.
