Overheating ka24e
j1rm
Car: 94 Accord auto. 90 Z32 (in the works)
I got a 1990 240 thats over heating, i changed the thermostat, water pump, fan clutch, and temp sensors
any clue?
AZ89two4Tsx
Radiator? Coolant leak? Hoses?
Could be a ton of things. Are you losing coolant?
j1rm
the hoses are fine, it was bursting out coolant a while ago from a hose but it got fixed, the radioator leaks from the bottom but not major, or enough to notice
Ryan_2.4litereater
Car: nissan 240sx S 13
thats exactly your problem right there. the most microscopic leak will cause your car to overheat. your car will eventualy loose pressure in the cooling system when it gets hot and will cause you to over heat, or the needle will fluctuate.
time for a new radiator
grecco28
Car: 1992 240sx
i recomend first check if there some air in the system is very common cause for over heating, if you can drain it and refill it again but with a special tool which make vacum first and then refill the system completely... you can find it in autozone or something is not expensive o go to a shop if you dont want buy it...
j1rm
dude, thats so not what i wanted to hear. U think OEM can take a beating? the other deal is that i bought that radiator 2 years ago from a junkyard, haha, i guess its a no brainer!!!
Ryan_2.4litereater
yeah. mine busted on me a few months ago. i never knew why i was overheating cause the crack was so small you couldnt notice it with out a dam magnifiying glass.n the coolant wouldnt apear cause it would evaporate by the time i opened the hood. i only found out by leaveing the car on and looking at the bay.
go aheand a grip you a metal radiator.
Cone Junky
Car: S13 fastback
BMW e46 328i
j1rm wrote:the hoses are fine, it was bursting out coolant a while ago from a hose but it got fixed, the radioator leaks from the bottom but not major, or enough to notice
If it can let coolant out, it can also let air in. Both of which can and will cause the car to overheat.
