overheating ka24de only with a/c on
af4071
Car: 92 s13 hatch ka-t powered!!
The engine overheats when A/C is on. This is something very recent. My car has never done this before and the ac has being working fine for the past year.
The following are my diagnostics: - It overheats only when AC is on, and backs down when AC is off probably means that thermostat is working properly.- The coolant is full. Took radiator cap off (when cold) and started the car, and there is coolant is flowing so water pump seems ok.- The belts, and hoses seems o.k.- I did not notice significant leaks in the coolant.- Condenser fan is working and the clutch fan is working too.- There seems to be no debris blocking the radiator and condenser
This is very annoying so please help.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
there is a fan for your a/c condenser. Your idle should raise up to 1200rpm and that fan kicks in to keep your temps stable. Check it! when you have a/c on and then off.
af4071
The rpms go up and the condenser fan comes on and is working fine. Maybe its the condenser or radiator itself?
