Bwana »
https://forums.nicoclub.com/bwana-u19793.html
Wed Nov 28, 2007 3:38 pm
After you have the system successfully bled you should have NO cooling issues with a CA. If you do it's likely your radiator, fan setup, ducting or the possibility that you have a leak in the system somewhere.
BTW, the stock gauge really only has 3 settings; cold, normalish and screwed.
