Jesda »
https://forums.nicoclub.com/jesda-u7038.html
Fri Mar 20, 2009 9:45 pm
My thermostat failed in a partially closed position. Not a common thing for the Q, but it happened to me.
If things havent been replaced, its time to do a full overhaul of your cooling system: radiator, WP, hoses, pulleys, belts, t-stat, fan clutch, fan blades, pressure cap. I ended up eventually replacing everything one by one until the problem was resolved.
Aftermarket water pumps, hoses, and radiators (I like CSF) are fine, but go OEM for the thermostat and pressure cap. The aftermarket thermostats, when fully open, will crush themselves because they are too large for the Q's thermostat housing. Also, the OEM thermostat is sometimes cheaper!
