marty1mc »
https://forums.nicoclub.com/marty1mc-u151866.html
Mon Nov 01, 2010 4:16 pm
I assume when you changed the thermostat you did bleed all of the air out of the system? If not, check the radiator and refill. I can take a cycle or two to get all of the air out. If you haven't bled the system of air, be prepared to dump a gallon in.
Next, start it up and look for moisture in the back of the engine. If you are losing enough coolant to overheat, you should be able to see it. There are a bunch of hoses back there for the heater core, turbos, plenum. Look it over carefully and look for leaks as it pressurizes. Also, look at the turbos themselves and make sure they aren't leaking from there. Are you seeing a puddle under the floor?
