NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Fri Aug 08, 2003 9:34 am
lift the front of the car up as high as possible, or park on an extreamly inclined road front pointed up. remove rad cap. remove the bleader screw on the front of the manifold near the 2 ground wires. fill rad till coolant comes out bleader hole. reinstall the screw ,continue to fill the radiator till its full. start engine and allow it to get to operating temp. top off fluid as you see it drop untill it wont take any more then install cap and road test.
