austins240 »
https://forums.nicoclub.com/austins240-u9789.html
Tue Jan 29, 2008 12:01 am
FSM FTW.
there's a bolt on the upper water neck. 10mm. you take it out and fill the radiator until water comes out. then put the bolt back in to stop the water coming out.
then fill the radiator. start the car with the heat turned to the "Hot" position.
let it run to operating temperature. continue to monitor fluid level.
fill coolant overflow. when engine is warm and coolant is flowing (upper and lower hoses warm/hot), top off the radiator and install radiator cap.
let engine cool, if there is any air in the system, the overflow should compensate and "bleed" the system.
but it's all in the FSM. think it says something about racing the motor IIRC.
