ItzGenX »
https://forums.nicoclub.com/itzgenx-u1074.html
Fri Mar 10, 2006 5:41 pm
When it comes to the cooling system, you do not want to leak or lose ANY coolant. When you come up with missing coolant, usually there's a problem. Now you need to find out where this fluid is going. Depending on what car you have will also help figure out the common problem for the scenario. I personally think you should stop driving it. Overheating causes further damage to the engine itself due to the heat stress and warpage possibility. Are you burning coolant? (sweet exhaust smell) Pull the thermostat housing and pop the thermostat out (not usually hard on most cars, especially nissans). Then reinstall the housing without the thermostat, so that you can rule out one problem. Correctly fill the cooling system with the engine running and heater on full blast. To help evacuate some of the air in the system, you could either open the bleeder screw or lift the front of the car off the ground about 2 1/2-3 feet. As the system warms up, continue topping the coolant off as needed until the temp gauge is normal and radiator is fairly warm (almost hot) to the touch. Do a final top off, put the cap on (make sure the black rubber at the bottom of the cap is not chipped or cracked, if so get a new one). Now fill the reservoir to the 'min' line and let it idle while you watch the temp gauge for overheating (do not let it overheat). If it does want to overheat, then you have other problems. Also, make sure there is no compression bleeding into your coolant. To test this, open the radiator cap and top it off (when cold). Start the engine and get a little warm (doesnt have to be operating temp). Now rev the engine to about 4k. Have someone watch the coolant as this is being done (remember the cap is off). It should SLOWLY run over the sides and then go back DOWN. If it SHOOTS out, you have a blown head gasket for sure. If that test goes fine, there is still the possibility with the head gasket being blown and coolant burning into the exhaust (white smoke/steamy--neutral/sweet smell). It is best before you do any of these tests, buy a bottle of cooling system flush for $5 at an auto parts store and flush ur coolant system as it tells you on the bottle. It also wouldn't hurt if you take a look at your water pump. You can warm up the car and look at ur water pump as the engine is running. On the water pump, there is a hole somewhere on it behind the pulley that will leak if the water pump seal or bearing has gone out in it. Also, if you are feeling adventurous, pull the pump and inspect how the impeller looks (could be rusted and missing a fin or two). As it has been stated, it is tough knowing exactly which route I gave you since we do not know what car you have, so I gave you a little of everything.
