overheating. countless hours searching...
whoareu
Car: 1993 rb25det s2 240sx vert
i know this topic has been exhausted but i am haveing overheating issues. My cooling setup is a godspeed radiator with dual fal220 fans. i also made cooling panels to keep air from escapeing between the fans and radiator. i do have a huge fmic that takes up most of the front. but i cant for the life of me keep the car from under 3/4 of the temp gauge. i will be getting a autometer temp gauge soon but dont have one yet. the car idle's at 1200-1500 according to the safc and i know it needs a tune and an adjustable fpr. my fpr is 40 w/o vacuum. when im high up in the rpm band the temps go down but if im not revving im overheating. and i have bleed the coolant numerous times. i am really beginning to think it is the water pump, but the guy i bought the motor from replaced the pump himself. when i try to burp the coolant system i cant really see it flowing through the radiator, but it will go down a little and then just starts overflowing at the cap. does that mean its the thermostat? im freaking at wits end here. and i have seriously searched this forum and others to find answeres to my questions but cant really find anything like what i stated.
Joe
change the tstat for cheap insurance but it wouldnt be the first pump to grenade itself in a Rb.
whoareu
so it sounds more like the pump to you? reason i ask is because it will run at normal operating temp and then after say 10-15 minutes the temps start creeping up if i dont keep her up i the rpm's
Joe
could definitely be a pump, or a blockage.
streeteg
From the sound of it it looks like you do have blockage or your thermo might be sticking.
I have a nismo thermo if youre interested--shoot me an email if your interested.
[email protected]
s14_sport
before making any changes to your setup....try bleeding the coolant system again.
It took me a good 45minutes to an hour to completely bleed my system the first time I got the motor running.
car jacked up in the front, rad cap off, motor on....keep refilling coolant as necessary
Initial_R90
Car: 2003 Zo6 Corvette RIP BLOWN up on the dyno
2003 Evo VIII
pressurized coolant flush , thermo, take the pump off and check it out
whoareu
when i try bleeding the system it always overflows. then when i turn the car off it eventually settles and i refill it. it has a greddy IM if that makes a difference.
whoareu
Initial_R90 wrote:pressurized coolant flush , thermo, take the pump off and check it out
cant you check the pump out with the thermo removed?
gawdzilla
Car: none
might be a dumb question but i'm surprised no one has asked this.
What sender are you using to your water temp gauge cluster? If you are using the RB sender the gauge cluster will read wrong (show hot when it really isnt)
jrb92se
Car: 1989 Nissan S13 coupe
i have a rb25 it took me about an hour to bleed my system you have to go get the kit from discount auto with the big yellow funnell. it never worked for me just jacking the car up i had to use the funnell and then jack it up . but other then that i think your thermo is stuck, just my opinion. did the previous owner replace the stat with the pump? ive heard and read a few times that the rb series of engines can be bad with having bubbles n the coolant. also i use the rb25 temp send with the oem 240 gauge it reads accurately.
jrb92se
mod delete please it posted twice.
95RB20S14
Car: 1995 240sx
I had an overheating issue so I replaced the thermostat with one from a 300ZX and it fit fine but it was not opening. I removed the thermostat and it cooled fine. You have to put the thermostat in just right or I think its easy to bind it up. Check your bottom hose and see if it ever gets warm. If it stays cold when the temp is up then I'd say that's your problem.
whoareu
it gets hot. im thinking my thermo may be stuck open.
