bahamet »
https://forums.nicoclub.com/bahamet-u80724.html
Mon Mar 17, 2008 11:12 am
Guy, you're missing the obvious. The car has not been bled properly of all air from the coolant system.
I had the same damn problem after replacing the T-stat and water pump. Soon, this condition blew a massive hole in my rad, and I was forced to get a new rad. It took me about 2.5 wks of minor tweaks to 100% bleed it.
If you have blown a HG, you'll be blowing constant white smoke out of the exhaust. I have seen enough TC cars exhibit this trait of a dying motor.
Now, engine coolant temp sensor might be bad, because my MPG has lowered from a constant 24-25 mixed MPG (250-270 miles w/ 1/4 tank left to spare) to a lowly 20-21 MPG (below the 1/4 tank at 220-230 miles). No CEL. I do not look forward to bleeding the coolant again.
