StarPD »
https://forums.nicoclub.com/starpd-u54244.html
Thu Aug 21, 2008 7:13 am
In 1974, I tired of rowing my Corvettes through city traffic and sweating myself nearly to death in Chicago summer heat/humidity. Bought a new Corvette with 454, auto, and A/C. Moved to Phoenix then. It ran hot, naturally, so I went to a good radiator shop. There I learned that a really GOOD rad shop can make pretty much any kind/size/type radiator you want. The only constraint then is fitting an oversized one into existing mounting, and allowing for some spacing between A/C condenser and radiator, depending on design air flow pattern. In my case, rather than replacing the radiator, I had the shop where I worked cut an aluminum front spoiler about 2" deeper than the original rubber one and fastened it with bolts/nuts to make replacement easy when I bent it in driveways and on parking bumpers (I had them make up several for replacements). The additonal air it scooped and forced up into the condenser and radiator solved my problems at road speeds, I just had to watch it in city traffic. But that was to solve an inherent design shortcoming, not a component failure.
FWIW, custom radiators are not that terribly expensive. My '05 Q45 runs fine in Phoenix heat now, so it's not a problem for me, but if I had cooling problems that weren't due to water pump, I'd replace my radiator with a GOOD HD custom one from a reputable shop. If you visit a GOOD rad shop, you'll be amazed at the many different cores they can use to make up a large capacity radiator with great air flow.
At any rate, regardless of what radiator you have, flushing the cooling system every two years is cheap insurance. If the radiator is clogging from aluminum corrosion due to exhaustion of anti-corrosion additives in the coolant, the inside of the water jackets in the motor are being eroded and can lead to catastrophic failure. Common sense maintenance, however expensive, is a lot cheaper than parts and labor for repairs.
My old Latin teacher, Father Hren had two sayings he repeated regularly:
"A word to the wise should be sufficient"
and,
"It takes all kinds, and we get 'em".
He was right on both counts.
