Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed Feb 27, 2008 10:22 am
There's only the one on the water neck AFAIK
The procedure I use is this1- turn your heater to full hot. If you close it off, your heater core will trap air in it and you'll never be rid of the air pockets2-remove the bleed screw on the upper water neck3-fill the radiator until water starts to come out of the bleeder screw4-install bleeder screw5-continue filling until the radiator is full6-start the car7-Wait for the car to reach operating temperature. At this point, the thermostat should open and the water level in the radiator should go down slightly.8-top off the radiator
I have used that procedure on the umpteen billion radiator fills I have done over the years on S-chassis cars.
As far as your coolant leak is concerned, make sure that you installed both copper washers. Since I assume you have an S14 SR (being a UK S14 car), you should have the copper washers that are connected on both sides of the banjo bolt. If you do, I'd suggest replacing them as they've probably been crushed past being useful. Other possibilities, though, could be dirt on the washers (and I mean a big piece), or the banjo bolt isn't as tight as it should be. However, copper washers are cheap.
