compression »
https://forums.nicoclub.com/compression-u9345.html
Tue Jan 27, 2004 1:45 pm
I finally got to start my car for the first time since the complete motor rebuild (long story). But it heats up incredibly quick and doesnt cool down. I have removed the thermostat.Here is the method I am using to fill the engine with water. Remove bleed screw on upper radiator neck on the side of the head (behind cam sensor). Jackl up the front of the car as high as my jack will go. Fill the radiator until water comes out of the bleed screw. Install bleed screw. Keep filling until the radiator is full.I am not using a heater, I have a small 180degree bend to join the two heater pipes. Can anyone advise why there still may be an air bubble in the system, keeping the water from circulating?thanksp.s. this is in a datsun 510, not a 240sx.
