overheating, again....
Audi180
Car: RB26'd S14
i now this subject have been allready overdiscussed...
but...
all the threads i've found, are about the rb25/20...
now, i have an rb26...
and it's overheating under boost.., wot at 2'nd, and in the end of 3'rd it's to high...
can anyone who uses the rb26 on an s14 help me with this?
i need to know who uses which rad and fans, and where can i get them...and if someone knows his temps under boost...
thanks a lot...
Tom
Ramius83
Car: 1995 240sx SE
Well, help up out here.
What fan setup are you using, and placement of the fans? Is it wired thermostatically, or are they 12v ignition?
etc etc etc.
Audi180
Car: RB26'd S14
some custom-god-knows fans
wired to my haltech... starts to work at 80C...
thanks
s13_rb25det
Car: s13
my mechnic has a haltech E11 v2 installed in his cosworth and he has a good system figured out...
2 fans...
@80C : one fan starts running@90C : second fan turns on in addition to the one and both run @ a higher rate
that solved his overheating issues...
nick
Bluefire
A lot of the cooling tips given in past threads are not motor or even car specific... Please search and read the posts over again, they contain a lot of info
-Bluefire
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
Bluefire wrote:A lot of the cooling tips given in past threads are not motor or even car specific... Please search and read the posts over again, they contain a lot of info
-Bluefire
Thats what i was thinking, overheating is a general problem, Krayton told me about ducting, i made a peice for the bottom between the fmic and the condensor and 2 peices on the side and wow what a differance, but till not good enough for city driving but i have new fans on there way out with a new koyo and a bottle of watter wetter, try the ducting, or find some good fans that flow good cfm's.
hashiriya13
Car: Cars, Racing, Cars, Racing
Depending on how the motor was installed, (kit or crossmember) with a little fab work cutting and ect. the radiator can be moved forward and allow the clutch fan to be used. that will solve allot. There are countless GTR's here in hot *** okinawa with no over heat problems with just the stock clutch fans. I will know first hand with the 26 in a day or two running off a r32 GTST radiator with just the clutch fan. As for 2 fans, pushers with a KOYO I have on my s13 RB25 in socal I had no problem (running off the ignition, always on) When i put the 26 in the 240 when I return my plan is to do some cutting and use the stock fan with one pusher on a temp switch. due to the 26 running hotter. Sorry I don't know any under the hood temps.
RB20DETodd
hashiriya13 wrote:Depending on how the motor was installed, (kit or crossmember) with a little fab work cutting and ect. the radiator can be moved forward and allow the clutch fan to be used. that will solve allot. There are countless GTR's here in hot *** okinawa with no over heat problems with just the stock clutch fans. I will know first hand with the 26 in a day or two running off a r32 GTST radiator with just the clutch fan. As for 2 fans, pushers with a KOYO I have on my s13 RB25 in socal I had no problem (running off the ignition, always on) When i put the 26 in the 240 when I return my plan is to do some cutting and use the stock fan with one pusher on a temp switch. due to the 26 running hotter. Sorry I don't know any under the hood temps.
Clutch fans with the shroud would be badass too bad i cant run it i can barely squeeze my e fans as pullers
