rolanoko »
https://forums.nicoclub.com/rolanoko-u250226.html
Sun Apr 05, 2015 7:31 pm
Hello,
I have 91 Ka24de 240sx and when i bought her she was overheating (i should also note that the car sat for a year or two.) I went to go change the thermostat and saw that there wasn't one in there, i put one in it and still overheating. I went and changed the water pump also and it was still overheating. i bled the system by opening the air relief plug on the upper rad hose until i had a stream of coolant. I let the car ran for about 20 minutes and noticed that my rad was cold, upper rad hose was really hot, lower rad hose was cold and so was the rad. I'm going to check the thermostat again tomorrow and make sure that its still fine. If the thermostat is fine does anyone know what else could be wrong with it?
I also noticed that within 2 minutes my temp gauge jumps up to hot.
