Temporary wrote:OK, now the other day my aftermarket fan flutch slpit itself open, and i replaced it. The car still over heats at idle, and when i take the RPMs to 4000 it'll cool back down. I know i've heard of problems with aftermarket thermostats, but does anyone know of problems with aftermarket fan clutches or waterpumps. Cuase i think one of those are malfunctioning.
I thought about the Head gasket, but what are some more signs of the head gasket blowing???
Also what would cause my radiator resevoir to completley overflow??
Quote »The car still over heats at idle, and when i take the RPMs to 4000 it'll cool back down[/quote]
This is because your moving the water with the pump at a faster rate. which means your pump is fine.
i doubt its head gasket or it would always overheat never coolign down.
radiator resivor will completely over flow if your cap is bad.
go buy a new cap 5 $ and it cancells out that possibility.
