overheating 240sx
D Money
Car: driving illegaly
i replaced my thermostat and waterpump on my KA but, my car still overheats. I got pretty much all the air bubbles out by jacking the car up about a foot. does anyone have any suggestions as to what the problem might be? thanks for reading my post
D Money
p.s. the top hose gets hot, but the bottom one stays cold
navysnail
you need to unscrew the bleed screw, its by the temp sensor, make sure its cool before you remove it. when you remove it, then fill the radiator, when it starts to overflow, put it back in, top off the radiator, cap it and you should be good to go
Silvia007
Car: 93 Nissan 240SX SE Fastback
Remove top radiator mounts. Move rad towards engine, look in the front of the rad.
D Money
check for what? i know where the bleeder screw is(ive had a 240 for a few years now), ive been bleeding it for hours, their seems to be an endless supply of tiny airbubbles, and coolant is not flowing at all P.S. your car is nice 240 kid
s13sr20chris
sounds like a clogged radiator my friend. you could try to flush it but i would advise that it rarely works.
D Money
wehn i ran a hose through it water seemd to move through it alright, i think im gonna drive it to the mechanics in a few days, ill let u guys know what the problem is. thanks a lot for all the help anyways
