brite »
https://forums.nicoclub.com/brite-u6155.html
Thu Aug 19, 2004 2:57 pm
I had the exact same problem on Aug 13th (Friday 13th) and could only drive for about 1 mile then had to pull over and let the engine cool down but after about 6 times it cleared its self, Hmmm
Next day I drained the anti freeze and pulled the thermostat out, **remove the fan with the clutch drive by removing the four bolts and let it lay at the bottom of the front area***Remove 3 bolts holding the housing off and yes 1 is a little hard to get at but its possible. Remove the radiator hose and pull off the thrmo stat cover. Now you can see the thermostat, pull it off.Now clean both faces.. cover and engine face... really clean as you don't want a leak. Use high temp gasket eliminator or a new cover gasket, install the new thermostat. Should be 76.5C opening with fail safe valve in it. That's a wee hole with a sort of pin through it so that if your thermostat sticks completely closed you will still get a little flow so that you don't blow a hose.
Put fan back on and top off anti freeze through the radiator, and fill up the plastic reserv tank, remove the air bleed valve, its a bolt on top of the Top radiator hose housing. Pump the radiator hoses, when you get coolant out of the air bleed put the bolt back in, it has a copper washer so make sure thats on the bottom.That solved my problem and when I checked the old thermostat it opened at 83C but was not consistant so I think it was sticking.
Cheers,
