overheating 240
shift_jin
Car: 2003 Nissan Sentra SER Spec V
bought project car a couple weeks ago it probably been sitting for a half a year or more. didn't overheat after until a couple days later. at idle its fine but driving it gets hot i changed temostat burped it once changed radiator cap. please help. should i flush out the system? water pump? where is the water pump at? Help! i searched nico forums and saw that radiator needs to be replaced.
Felipe
Car: abcdefghijklm nopqrstuvwxyz `1234567890-= ~!@#$%^&*()_+
new pump and flush it while you at it. re burp.
the pump is attached to the fan. (thats if you have a clutch fan)
shift_jin
thanks i'll try that out
MadmikeX3
Car: 1990 240sx SRBLKTOP With a potatoe
while your at it grab an electric fan off a 3.8L ford tauras*. There great and they have two speeds to choose from, they even push more CFM than most Flex a lites
