Nothing two engineering degrees doesn't teach you and 18 years of dealing with Infiniti engines.
Very simple the inside gauge sensor is an immersion type thermistor.When the water is low or leaks out, the space around sensor is just air and eventually steam and thus cannot read above 212F.
Without coolant the engine keeps heating the aluminum until it decreases the bearing clearance and the oil cokes , engine siezes.
Q45tech doesn't stant for technican but TECHNICAL
As to tires and as a member of the Tire Society*, I would never buy Fstone or allow them on any car a friend owned. I won't drive a rental car which has more than 8,000 miles on its tires.In fact I've used nothing but Michelins for the past 600,000 miles and 34 years. Haven't had a flat during that time nor pulled a jack. I carry an electronic tire gauge every day everywhere.
http://www.tiresociety.org/mainpages/nhtsa.htmlThe Tire Society grew out of the ASTM Committee F-9 on Tireshttp://
www.tiresociety.org/pdf...b.pdf
