Overheated, up to 272F!! what to do now
pr240sx
Changed oil and even smelled like burnt plastic.Plug wires melted inside the plug holes. Car starts fine but I think that the head is warped.I plan to at least change the headgasket, valve seals.What else do I need the check/replace.Compression, before this incident, was 160~170. Engine runs quite good afterwards, no smoke, no nothing.I am quite impressed with this engine, I didnt think that the engine could hold up to that temp/abuse.
In case you wonder what happened, the lower radiator hose become loose and lost all the coolant. Why up to 272? trying to get to the emergency lane at rush hour traffic in a 6 lane highway in Puerto Rico is not a easy task!!
Any tips or recommendations?
KATwo40
Car: 1993 240sx KA-T
Check the compression again. If it's still fine and no smoke/vapor out the exhaust, then don't even change the HG.
Charlie240sxt
Car: 95 240sx SE Ka24det!!! 98 audi A4
yea compression check 1st then see what you got from there and new plugs
C.s240
Car: tunning
and were in PR is there a 6 lane highway??? its a 23lane and it crowed,i'm asuming u live in bayamon area ?u can also do a combustion check, to see if ur passing exhuast fumes into the radiator.i have run across this numerous times, the car wont smoke but it slightly overheats by the way CORRILLOOOOOO!!
ohhh i'm from PONCE PR laters BORICUAS IN THE HOUSE!! all u had to do was stick out 1/2 the window and say CABRONES SALGANSEN DEL MEDIO PUñETAA!!
pr240sx
Just in front of Plaza Las Americas, there is a "sliding" lane and from a normal 4 lane, changes to a 6 lane.Will check compression today and let you know guys.Only thing strange is that rad fans (altima) are working quite too much.Anyway, car runs strong, amazingly strong.
