Portugese Bend wrote:Use the search on this website. It's nothing new and it happens frequently. I did the hardest part for you, which was to make the diagnosis.
and if u do replace...suggestion would be with one that has the red tab to release pressure wihtout turning the cap....drift or die wrote:the same thing happened to me mine was the head gasket what i did is i went to a chevy dealership and bought some coolant tabs that you put in the radiator and it seals up everything including the head gasket and it worked perfect you could probly buy them at autozone... and you might wana try the radiator cap replace that its only like 10 bucks
