Brads_SR20DET »
https://forums.nicoclub.com/brads-sr20det-u13175.html
Fri Oct 03, 2003 4:36 pm
i actually have basically the same problem that you are describing. i have a '91 fastback 240 with a sr20det swap. i started smoking about 2 or 3 weeks ago and though i was just burning oil because of the smell. it usually only did it while i was idleing at a red light or parked.... however, in an effort to figure out what the actual problem was i took it to a mechanic, and he had several ideas....first being that my head gasket was goin on me, that would account for the white smoke, but you said that there were no bubbles to indicate that air was leaking. second, that it was a cracked header, and that condensation was building as it would int he case of a blowing gasket and was being burned as steam. third, i dont know if your injectors are hanging up, but mine are and the thought that they were loading up and spittin oil was a suggestion. lastly, i dont know if you are turboed, but they said that there may be oil leaking in my turbo. thats what they had to say for me...and by now you may have already gone to a mechanic and figured out what it is....if so...reply and let me know so i could try to diagnose my own car.....thanx
