Overhead DVD in 2002 Pathfinder
sdhinton
Looking to install an overhead dvd player in my 2002 pathfinder LE. Does the sunroof interfere with installing an overhead unit? Doesn't appear to be much room behind the sunroof. Anybody ever done this and do you have pictures?
Thanks
ganesh21
Car: '12 Honda Pilot
i have done it on last pathfinder - 1996.
there is a little bit of a room available. what will happen is when you pull back the overhead (the cover under the sunroof)- it will get scratch.
the sunroof will open and close fine. there are some brackets that is under the sun roof, which i used to mount the flip down tv.
ubpsanity
Car: 2001 Pathfinder SE, 1999 Mitsubishi Eclipse Spyder
Wasn't there a factory overhead option in the later models? If the factory can do it, it must be possible to do it to look factory.
