Ls1pwr wrote:if the width of tires didnt matter or help traction then the new z06 would have 205's instead of 325's out back.... if you take a 245/40/17 es100 for example and compare it to a 275/35/17 es100, which one do u think will have more traction? also i am setting this car up for road racing and i need traction everywhere not just in a straight line, so if you are not going to contribute to the thread please dont post in it. thanks
If you wanna be a smart guy I'll just pick you apart.
Those big wheels you want to run are going to greatly increase your unsprung mass which will decrease stability on a rough track, especially if you choose any of the off the shelf solutions to the 240SX in suspension.
They will also reduce the dynamic load placed on the tire due to an increase in track width, thus reducing the need for a wider tire since the dynamic load is shared more evenly over the two tires (laden / unladen).
Incredibly wide tires require alot of friction to generate heat. You will find that it will be hard to keep heat in the tires since the 240SX is such a light vehicle. Especially if you are on an open track and lack aerodynamic assistance, which at this point is a guarantee since you don't even understand balloon theory.
Wider tires and wheels that impart into the slipstream, and flares all GREATLY increase aerodynamic drag.
Running a wider wheel, especially one that requires a greater negative offset will affect your dynamic suspension geometry. The scrub radius causes the car to become very nervous, especially under braking. That's why modern race cars hold their contact patch inboard and maintain a relatively neutral scrub.
Your car is not a Z06. Your car with an LS1 is not a Z06. The Z06 has significant advantages over a 240SX in nearly every regard. That is quite possibly the most horrendous excuse for a lack of knowledge I have seen in a good while. It reflects your general lack of understanding on the entire subject.
If you want to build a race car that works worth a damn you might want to do some research and stop puffing your chest out at those that know something.
