Overdrive on or off?
Zouka240sx
Car: 1991 Nissan 240sx KA24DE
Is it better to leave the overdrive on or off? I've heard it's better to just leave it on, but doesn't that have a negative effect in the long run?
Razi
Car: Moo
Leave it on.
nismoracingsx
Car: 1993 White 240sx Coupe
with the button not pressed in, you're essentially removing 4th gear...runs your engine harder and kills the gas mileage..
Zouka240sx
Good to know. I've just been switching back and forth and started to notice the gas mileage was horrible so while I had gotten the advice to leave it on, I wasn't 100% sure and then someone else had told me the constant switching was normal. Though doesn't that heat up the transmission and shortens the life of it?
turtle240
Car: 93 s13 koop
yea i made that mistake before the 5speed swap. i had it off and didnt know it so i put the pedal to the floor to see what it had and then my trans started smoking. once i realized it it hasnt smoked scense
still i added a little fluid to compensate for the stuff that burnt uponly like 1/2 a quart i needed some anyway
