Overdrive Off button for regular downshifting?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Cash_22
Car: 2009 Nissan Versa S
I read in my automatic transmission Versa's manual that the O/D Off button on the gear knob is used for going downhill only (i.e. engine breaking) and in emergency manuevers. I've driven other cars before with these feature and I've always thought that you could use this button fairly regularly such as overtaking on the freeway, or downshifting uphill. The manual also says that to downshift, just press the accelerator all the way down. I'd prefer using the O/D Off button and save some gas. What's your take on this?
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
I don't know how you drive, but usually the O/D off will not save you gas. It will give you more power because will be running a higher RPM. The O/D is meant to drive the wheels as fast as a lower gear and use less engine power to do so.
If you shift in and out of O/D a lot by constantly trying to pass and keep the RPMs higher, I'd personally recommend running out of O/D. Usually the constant shifting in and out is what starts to wear on the transmisson.
NODES
Car: 2007 Nissan Versa SL (Blue)
I though the O/D Off is for going up steep hills or towing...
BigBodyV
Car: Nissan Versa S
Yeah u can use it to downshift thechnicly thts what the ransmision is doing anyways so there shouldnt be any harm in any sort of way.
Return to “Versa Technical Discussions”
