NISTECH wrote:It is not suppose to blink at all unless theres a problem. It will come on when the key is cyled from off to on though that is a bulb check feature.You are correct about od not kicking in till it reaches operating temp.
uh oh, time to check my transmission
Quote »check your trans fluid level. when it does that it is indicating a problem in the trans that will not let it go into overdrive. once the problem goes away the light stops flashing.[/quote]Mine stops flashing about 2-3 seconds after the car is on. Then the overdrive light stays on. So, would that mean there's a problem? I know there is a small leak going on right now with the trans fluid, which I will be taking care of next week, but other than that, I have no idea what would be wrong. I definitely know overdrive is working because when I switch it off there is a huge difference in "feel" and the rpms are at different places during different speeds.
