wmcvetty wrote:ARKQX33V6 wrote:Can you determine if the engine speeds up also as the tach does or is it just the tach speeding up?
How would I determine that? May be a stupid question but the more I thought about it I was unsure.
To determine if the engine is actually speeding up at the same time as the tachometer indicates higher speed:
Listen to the engine,
Try downshifting to increase engine speed, is it normal sounding,
Get another tachometer and relate the car's tach to the test tach,
Measure the alternator voltage at the cigar lighter, does it go higher
Read specific voltages via the ECM
But the easiest is to listen to the motor
