Structure240sx wrote:compression test it. and your turbo has got to be shot. im very sorry to hear
ftrs13 wrote:maybe you got lucky with the turbohope the engine is ok
Yes, but not like 5mins after the race, since that's about how long it took me to reach the parking lot and pop the hood. It's a first for me:: orion :: wrote:Turbo red hot is normal...think, your EGT are in the 1500-1600 F range...that'll get a cast iron turbine glowing red. I've seen my manifold, turbin, and the first 6" of my downpipe glowing orange under the hood
j-z wrote:so why did you even track your car knowing that you over boost going into third? thats your fault man.
ADAMHU wrote:yes the gain setting is very sensitive you should have it turned way down....
on my setup it doesn't matter i have the gain all the way up....at 14psi..it spikes to 19psi...before it settles down...
On my SR, I can touch the hotpipe coming from the turbo and it's not that hot. This is after a few minutes of hard running. My car runs rich and its an SR, but I thought it would be much hotter than it is.:: orion :: wrote:Turbo red hot is normal...think, your EGT are in the 1500-1600 F range...that'll get a cast iron turbine glowing red. I've seen my manifold, turbin, and the first 6" of my downpipe glowing orange under the hood - Do a long pull and then stop and pop the hood - You'll see.
- Brian
Def wrote:Hot pipe = Compressor outlet(intake air pressurized)
Exhaust manifold + turbo + downpipe = VERY hot exhaust
I wouldn't suggest you ever touch the turbine of your turbo after running it, as you might pull back with no fingerprints.
Red-KAT wrote:I cant belive your gain is so high!
I just got doen playing with my setup to hold 8psi better... I ended up with +33% from 6psi... (about 8psi) set the gain to 9 and my start at 7.0psi... (it sez to run your start at least 2.8 psi under the max psi... but this seems to work for mine with very little overshoot) I only overshoot to about 8.3 befor it nabs it back to 8.0...
The boost hits allot faster... I can tell it helped my car alot.
Yep, it is cheaper. But my heat wrap is already crap. It falling off from having to work on my exhaust gaskets time and time again.Xero wrote:I'm still a fan of new technology, especially when it's proven, so I'd suggest powder coating, but heat wrap is cheaper.
