virus77 wrote:if you want your SET boost to be 10 psi and you have inputed your START boost at 10 psi on the boost controller it will cause overboosting, you should set it 3 psi less then what you want your boost to be at. I noticed you said with the eo-1 off it still does it but that will make it even worse.
He's just seeing boost creep as Ivan said. A boost controller issue would have irregular control all over the boost threashold and is often time the result of too much duty and too less gain, or visa versa. Automatic modes on boost controllers also are hardly ever worth a damn.
As far as his problem... notice the VE of the KA, it gains very sharply at 4k which will lead to more mass flow. This causes an overpressure situation in the manifold that the W/G can not flow, so the air is passed over the turbine blade and you have boost creep.
