oldmako »
https://forums.nicoclub.com/oldmako-u82911.html
Fri May 02, 2008 4:59 am
No luck with the search.
In looking at the FSM there doesn't appear to be much detail regarding the overflow / rainwater drain below the filler opening.
Mine is clogged, and ends up making a mess when rainwater and or car wash rinse sloshes out as I poke down the highway.
It appears to be clogged right at the entry point, and I do not wish to simply jam a screwdriver into the clog without knowing where that water goes afterward.Is there a hose which takes it to the bottom of the fender area and then overboard? My concern is that the water may end up inside the fender and lead to rust. I'd like to try and flog this thing for several years.
Thanks for any info oh so knowledgeable QDudes. I genuflect in your general direction.
