Clatch »
https://forums.nicoclub.com/clatch-u17761.html
Wed Jan 19, 2005 3:01 pm
The Car: 1993 Nissan 240SX FB SE ManualSo I had my Clutch Master Cylinder and Slave Replaced only to find out a how to do it in Chilton's later :/. Anyway after it was replaced I was driving down the road and the 240 just revved up almost to redlined while it was moving, like if I had pushed in the clutch and revved while going about 30, but I hadn't put in the clutch. After that it wouldn't let me go over 30mph under moderate acceleration without free revving. After I got home I smelled the nasty smell of a clutch burnt. Now I had this problem before and the way the mechanic fixed it was to tighten or loosen some bolt on the back of the clutch pedal. How do I do this, what bolt is it, which way do I turn it, and how much? Here are some pictures I took of the back of the clutch pedal so you can point it out to me, err they will be up in a few minutes.
EDIT: Hmm, photos are being a pain right now, I will try to get them up later, but right now I think its the gold nut and thread, I'm not sure.
EDIT: Here they Are! If you need higher qualitly pics, or different locations of the pedal, I will readjust the camera and try it agian, its not exactly easy to take these pics.
Modified by Clatch at 1:16 AM 1/20/2005
Modified by Clatch at 1:51 AM 1/20/2005
