480sx »
https://forums.nicoclub.com/480sx-u50548.html
Thu Apr 17, 2008 1:24 pm
The valve cover does not hold itself onto the heads. The bolt goes through the valve cover and into the heads. You stripped the heads. What you really need to do is determine how bad the threads are stripped. If you were really... Forceful, then chances are you need to use a helicoil. If you stopped turning before you did a crap load of damage, then you might be able to get away with a tap and dye set + low TQ on the bolt.
