SilviaS14KA24DE »
https://forums.nicoclub.com/silvias14ka24de-u14571.html
Thu Apr 15, 2004 3:48 pm
you probably don't need larger valves. but hell if you've got the money to spend with the snap of a finger, then do it. List your mods, and I bet the whole community can give you advice and opinions on what you should get.
[EDIT]
Well don't I feel stupid? I just saw your sig and well, there are you mods! If thats all you got so, and since you didn't list it in your mods, get a full cat-back exhaust, headers. Personally I like the Apexi N1 Dual Exhaust. As for headers, I hear a lot on this board that people commonly use HotShot headers.
If you're looking for just engine, here we go of possible things to do instead of larger valves:
1. get a lightend flywheel. Daily driving will probably be a ***** because you're rpms will drop FAST. But hey if you want performance, you gotta cope with it. Personally, that will be one of my first mods.
2. upgraded clutch and pressure plate. Yes, you need that clutch to catch HARD.
3. '91 s13 cams. Exhaust or intake cams i dunnol. Do a search. I beleive exhaust cams is the common mod.
4. fuel pump/filter. Well i upgraded my filter to a 300zx turbo filter, and the pick up has improved a lot - but my car is N/A. So I dunno if this will make a difference since you are turboed.
Don't you want your ride to take 'em corners? You can't go fast without control. Suspension includes of:
Strut bars, tie rods, tension rods, sway bars, upper arms, lower arms, and ladder bars.
Well, personally I think it's a waste to get larger valves. These are some things you can do inplace of that.
